Gönderen Konu: Yaris Carplay TAS500  (Okunma sayısı 1992 defa)
  • 2013 Yaris Cool + 2019 Corolla Dream /MultidriveS
    • tistateknoloji.com
  • Kilometre: 1000
« : Mart 01, 2021, 15:30:00 »
Arkadaslar merhava,
2013 Cool yarisimin multimedya ekranini degistirmek istiyorum. Yabanci forumlarda biraz arastirdim. Touch 2 versiyonunu TAS500(CarPlay) modeli ile degistirebilenler olmus fakat geri gorus kamera sorunu yasamislar.
Touch1 ekranimi TAS500 ile ayni soketleri kullanarak baglayabilirmyim? 2013 ve 2014 model arasinda on konsolda ufak bir fark var. O yuzden multimedyanin casei uyarmi emin olamadim.
https://www.toyotaownersclub.com/forums/topic/194071-reverse-cam-for-tas500-in-hybrid-from-2014
Parca bu : https://allegro.pl/oferta/toyota-yaris-iii-2020-radio-navi-nawigacja-9864411831
Parca Kodlari : https://www.toyota-tech.eu/aimuploads/4ad1988e-d731-4be4-89d5-fbcab20c370a/Yaris_TAS500_PW600_0D001_AIM_004_322_3.pdf
Yurtdisina rahat gidip gelebilidigim icin avrupada bir cikmacidan alabilirim.
Aliexpress de gordum fakat bu TAS500 modelini ureten Harman bu yuzden kiyaslanmaya degecegini sanmiyorum.
Aliexpresde satilanlar : https://tr.aliexpress.com/item/4000971417803.html?spm=a2g0o.productlist.0.0.769884f8ytWwID&algo_pvid=125c9b59-d357-4d6d-81c2-544190f212c2&algo_expid=125c9b59-d357-4d6d-81c2-544190f212c2-3&btsid=2100bb5116145341734001504efc35&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Guncelleme ile gelen ozellikler.
TSB: BE-00233T-TME Version 1 16 Apr 2020
Subject: TAS500 Display Audio-unit - Minor Bug-fixes and Software improvements
Area of Application: All Markets
Models – Model Codes: Yaris - KSP130, NHP130, NSP131
Description of the phenomenon
Below overview lists the issues that some customers may experience and report, and which have been resolved in a subsequent Software-release.
TAS500 Software release EU_19.6.0
DEFAULT PARAMETERS : Default Audio Source changed from Audio OFF to FM upon Factory reset.
DEFAULT PARAMETERS : Default Volume-level changed from 7 to 12
BLANK SCREEN : After ACC ON, head-unit stays in blank screen (rare condition)
DIAG. MENU : External Microphone fault not detected if the Microphone was not connected during start-up.
USB-PLAYBACK : USB noise heard while media getting paused or playing the next track.
USB-PLAYBACK : Using Multilaser brand USB-device doesn't work
GENERAL : Backlight EEPROM Data is written on every power cycle, causing excessive EEPROM usage.
ANDROID AUTO : Android Auto freezes when touching and holding map or scrolling through menus and at the same time another event happens outside Android Auto and the user releases finger from the screen. (Ex.g. press Home key and pop-up is triggered by pressing Volume via the Steering-wheel or Head-unit hard keys)
bluetooth PAIRING : bluetooth Device Search operation does not time-out when no device is present nearby.
TRANSLATIONS : Updated translations in Danish, Greek, Spanish, French, Norwegian, Portuguese, Swedish.
ASL : In some cases, a dip in audio can be noticed due to ASL-feature, especially at high speeds.
Apple CARPLAY : In some cases, after selecting "YES" on the first time pop-up (iPhone X), Car Play doesn't launch correctly.
Apple CARPLAY : On start-up, with iPhone 8 connected and Car Play active, performing a reset of the phone causes the TAS500-system to reset. After restart, Car Play and Android Auto are disabled.
The update is available via Techdoc HERE or via repair of a warranty complaint at your Toyota dealer.
Gorunusunu ekledim.
2013 Toyota Yaris 1.33 Cool MultidriveS - Touch 1 - Geri Görüşlü ve 2019 Toyota Corolla Dream MultidriveS + Park Sensörü
