GENERAL
Body type Hatch
Drive FF
Transmission 5 speed manual
Displacement, cc 1496
Frame TA-NCP13-AHMVK
Price of new car, thousands yen (Tokyo area) 1505 (~$12500)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 3630 x 1660 x 1485
Interior dimensions (LxWxH), mm 1820 x 1380 x 1265
Wheel base, mm 2370
Treads (F/R), mm 1445 / 1420
Ground clearance, mm 120
Curb vehicle weight, kg 950
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 5.3
Fuel tank capacity, l 45
ENGINE
Engine model 1NZ-FE
Max.power (Net), kw(PS)/rpm 110 ps (80.91 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 14.6 kg*m (143.18 N*m) / 4200 rpm
Power density 8.64
Engine type Serial 4 cylinder DOHC
Engine information VVT-i
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 10.5
Bore, mm 75
Stroke, mm 84.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.8
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 185/55r15 81v
Tires size rear 185/55r15 81v
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Strut type coil spring
Suspension system, rear Torsion beam type coil spring
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof Option
Front fog lamp Present
Rear fog lamp Option
Xenon headlight (Discharge lamp) Not Present
Projector headlight Not Present
Rear wiper Present
Front spoiler Present
Rear or roof spoiler Present
ABS (Antilock brake system) Present
TCS (Traction control system) Not Present
LSD (Limited slip differential) Not Present
Privacy glass Option
UV cutting glass Present
Aluminium wheel 15 inch standard
INTERIOR EQUIPMENT
Air conditioner Full automatic
Wood panel Not Present
Cruise control Not Present
Centralized door lock Present
Power window Present
Steering wheel telescopic Not Present
Steering wheel tilt Present
Leather steering wheel Present
Power front seat Not Present
Power rear seat Not Present
Leather seat Not Present
Falling down type rear seat Divided type
Child seat fixed with seat belt Present
Rear ELR3 point seat belt Present
Front seat pretensioner seat belt Present
Fourth limited front seat belt Present
Side impact bar Present
Airbag (Driver) Present
Airbag (Passenger) Present
Airbag (Side) Not Present
Audio deck AM/FM radio equipped cassette player
CD-player Single equipment
Car navigation system Option
